I have a 29 year old Potterton Netaheat 10-16 MkII which seems to be causing a problem. With the thermostat turned down the water heats up as normal & radiators remain cold. If the thermostat is turned up to heat the radiators this causes the expansion pipe/vent pipe above the feed and expansion tank in the loft to continuously run water (warm or cold) into the expansion tank whether the radiators are warm or not. If however the thermostat is turned down then the running water from the expansion pipe stops
