rust
If you have already plastered, I would wait and see. You can never rule out corrosion but providing the area is free from water ingress and high moisture levels, there should not be any imminent danger!
I wouldn't have thought they would rust easily. If they are 'capping' nails then surely they should be designed to go under plaster - as electrical capping generally goes under the plaster.
I imagine these are galvanised or plated.
