Hello everyone,
My Vaillant boiler keeps giving s53 code, and keeps cutting out and starts again every 3-5 minutes.
I called an engineer and he cleaned my heat exchanger and quite a bit of black metals came out.He said that this is the reason why s53 would be caused as it has a blockage somewhere
However after few days the problem started again for the fault code.The manual says that s53 is caused by lack of water,but the water is on 2 bar.He also installed magna-flow on the return pipe.
After trawling the forum and internet i have had no luck.Water works fine and the radiators in the house are all lukewarm,but not hot.I am wondering if someone here is could tell me if i need another engineer,or will the problem sort itself out after few days.Boiler has been running on for 24 hrs now non stop.
I am wondering if it is being caused by the capped off pipework in the new extension,which was meant to be for the radiators as the engineer has not picked up on this.I have not had a chance to get them fitted.Basically the flow and return pipe have been capped off separately only for 2 radiators.Would this cause s53 error code.Should the sealed heating system have a continuous run of radiators or would this result in the issues i am having.
Thanks.
Thanks.
