The cylinder has been moved into the loft and boiler is still on the ground floor, is there a clear option for where the control gear should be? I can see advantages and disadvantages to both. Thanks in advance.
Yes, sorry the OP wasn't clear. I will doing the pipe work in readiness for a boiler/ system upgrade.. The cylinder is in place, just trying to decide on the location of the valves & pump.
