H
holmslaw
Give it a rest, I've had jokes in Christmas crackers which are funnier than this.I'm not confused, but the only zones mentioned are top of a wall and corners of rooms. So all cables should emanate only from those zones and not from under floor to above. And the accessory does only sighifies a possible cable route to above, to a corner or vertically and horizontally to another accessory.
So how did it come about that cables can drop behind skirting boards?
I will not mock you as I consider that offensive and it's a reasonable question.So how did it come about that cables can drop behind skirting boards?
Don't be ridiculous - of course it's not.it's a reasonable question.
So they published the OSG's to cover up their mistake.
If you're going to start imagining words which aren't there then all bets are off.Those are the three sentences that comprise that sub-clause. Because they are in one sub-clause I consider them to be associated therefore all cables must emanate fom corners or tops of walls. Imagine the word 'and' between the sentences.
"be installed in a zone within 150mm from the top of the wall or partition or within 150mm of an angle formed by two adjoining walls or partitions• Where the cable is connected to a point, accessory or switchgear on any surface of the wall or partition...."
No, the standard interpretation sees them to be associated.522.6.6 (v) says...........
The standard interpretation sees the three sentences as unassociated, imagine the word 'or' between the sentences. So if they are unassociated then surely they should have been individual sub-clauses.
At the end of the day it doesn't really matter as this is a DIY site and as you know full well us DIYers are not bound by the regs![]()
