Hi
I'm in the early stages of planning a major extension/rebuild of our house. We have an Oil boiler house boiler (Grant 70/90) open vent system and I'm thinking of reusing this boiler with a closed setup.
My question concerns safety. In my current setup loss of water from the heating side would get topped up from the header tank. However on a sealed system this isn't the case and as I understand its up to the householder to periodically check the pressure and top up via the filling loop if required. But if I'm reusing my current boiler it has no flow or pressure safety cut-off to stop the boiler firing if its dry - which I think most sealed boilers do.
So my question: What do people normally do when considering such an install. In my simple mind I assumed you'd be able to buy a pressure or flow sensor and wire that in to the boiler call circuit - but since I cannot find any of these online I guess it either not the done thing or not common.
Any thoughts?
Any thoughts?
