I'm creating a bathroom that is a little bit different. I've jsut fitted a sail shaped bath/shower screen. However the supporting batton that is meant to fix against the wall is only supported 2/3rds of the way up as there is a massive window + associated shelf in the way. I've screwed the lower part down substantially, but i want to restrain the top. In keeping with the shape of the screen, i'm considering running a series of wire ropes from the frame in different angles and lengths to the window sill to make it look like a proper ship's sail.
I've found places that can sell me the kits used in shops, www.midwestdisplays.com but they're very expensive considering the number of ropes/fixing i want to use (6-10)
it'd be much better if i could use a series of eyelets and a series of tensioners, touse only a single kit with a massive length of rope and run it back and forth.
Does this all make sense? it's in my head but nowhere else at the moment. Anybody got any suggestions they care to wing my way? sources of eyelets that can screw into wood and allow the wire rope to run through? sources of wire rope fixings?
Cheers
Cheers
