Hi. Fairly novice to plumbing but and like advice. Fitting a shower pump that has some anti virbration connectors (basically 8 inch flexi hoses) which are 22mm tap onto the pump at one end and and 15mm push fit at the other. 4 of these and are for hot and cold in and out of the pump.
All pipework from the hot water cylinder and cold water storage is 22mm which went directly into the old pump using old valve and tap connectors which I want to get rid of. I'd like some advice on how you would take the 22mm into the 15mm pump connectors (do you need a reducer, or can you get flexi, copper?). Or, would you not use the supplied hoses and just get 22mm all the way into the pump? Thanks in advance.
