I have a salamander esp 140 cpv installed on ground floor beside hot water cylinder with cold tank in loft (above floor 1). Pump feeds hot and cold to floor 1 only - ground is gravity and mains. It has own direct supplies from hot and cold tanks as specified etc.
It has started switching itself on and running very briefly (a few seconds at most) then off when the bathroom's not in use. Could be half hour after bathroom last used, then an hour or so later, then maybe a few hours later/middle of the night etc.
Any ideas please ? I assumed that if there was a leak, it would switch on more frequently and for longer - can't find a leak anyway.
Only thing I wondered about was whether the water in the toilet cistern was settling down and causing the pump to start. The cistern has high pressure fitting though.
Any ideas please ?
Any ideas please ?
