Hi All,
I'm new, so to start with I'd like to say hello!
I have a RHP100 (2 years old) fitted under my bath which feeds the bath and shower via a mixer (the sort with a temp gauge in the middle, a lower tap for the bath and a upper tap for the shower).
Recently I have noticed that the teperature is too cold when using the shower, but comes through much hotter if I turn the bath tap on and off again (but then goes cool again after a few seconds).
I have had the pump run dry a few times due to the header empying, but have stopped the pump as soon as noticed and managed to get the water back through the pump once the system has had time to fill up.
I'm concerned about cavitation / wear on the pump due to airation. Do my pumps symptoms suggest this could be the problem?
Any help or suggestions would be greatly appreciated.
