Hi sorry to jump straight into a question post and being new to the forum. I am usually able to sort sort DIY stuff my self so never needed to join a forum.
Our new property (1920 solid brick partial concrete and partially suspended wood floor) came with a damp survey and recommendations were a chemical dpc. Removal of plaster upto 1m and a salt retardant backing plaster added. Lower external ground level and 4 more air bricks.
My question is we were planning on dry lining(because the house is cold) possibly with kingspan insulation between steel studwork. Do you need to use a salt retardant backing over the exposed brick work upto the 1m previously removed? por would you just remove all the plaster back to the brick work to ceiling height and then stud, insulate and board then skim. Another thing do I need to add a vapour barrier?. I don't want to end up trapping moisture behind the stud wall.
I know ultimately that external insulation and rendering would be best but that works out quite expensive and I don't know how good I would be at rendering an external wall with how large a surface that would be having only plastered a handful of walls and ceilings.
