Model is RT50RF
Seemed maybe yesterday as we noticed the temp in house was dropping below the set temp, but turning the set temp up and then back down ( on manual ) seemed to work . It must have been working overnight as the heating came on this morning on auto but then it seems to have completely lost the connection .
Initially there was only a red light on the receiver .
Turned the power to receiver off and switched it back on and very briefly the green light came on , boiler fired up , but then green light went off and boiler switched off.
Took batteries out of thermostat and turned power to receiver off and waited 10 mins. When power to receiver was restored we had red light flashing and green light was on. Put batteries back into the stat and went to pair in menu and let it count down and it still didn't pair . At some point ( the boiler is in the garage) before the 10 mins was up the green light disappeared.
Anything else we can try and any recommendations for a new remote thermostat please ?
Thankfully we've can get the heating on by turning the receiver to manual, but obviously no control over it and it's a bit of a pain having to keep going in and out of the garage ( which of course lets cold air into the house )
I'd rather the temp in the house didn't drop to 14c overnight ( we have it on auto set to to 17c overnight)
If we leave it on manual overnight and turn the radiator water temp down lower will it do any harm as aware that means the pump will run all night?
Any idea what sort of temp we should turn the temp down to?
Thank you.
(As a side note , I've read some of the other posts and someone suggested interference. We haven't changed anything , but aware that they've been putting VM cables in in our street and the metal cabinet thing they put in that is about 15m from our house . Yesterday a VM van was here briefly doing something inside the cabinet)
Thank you.
