- Joined
- 28 Oct 2018
- Messages
- 4
- Reaction score
- 0
- Country
Hello there,
First post as I can't find any similar problems on the forums here.
A few days ago, woke up to no electricity around the house. Saw the MCB main connection had tripped and wouldn't come back on. Did the usual checks and turned off all appliances etc. and cut a long story short, found the fridge freezer causing the fault.
This afternoon, checked the flex cable had some chaffing in it, cut it and to test, plugged in live and neutral into an extension cable and tested and it worked fine (didn't plug the earth cable in).
Connected a 13A top plug and plugged it in and the circuit blew. Only difference between the first and second time was the earth cable plugged in.
I therefore isolated the earth cable from the top plug and tested and lo and behold, it started working! This proves that when the earth cable is connected from that appliance, it's tripping the MCB.
Have disconnected the fridge freezer as am not sure what is causing this and how to go about fixing and if necessary, whom to call out to repair this fridge freezer.
