Bought this along with the house ~3 years ago. Just replaced the water filter and was flushing a lot of water through, when it became apparent that water was running across the floor.
The water only leaks when it's dispensing, so the leak is after the dispensing valve.
I've got the RS21 series service manual, but a quick skim doesn't show where the water pipes are - I'm assuming that one of the most likely causes is a plastic pipe that's cracked with age, or a joint that has come apart, but I guess there must be more possibilities.
I'm open to advice as to where to look and how much I have to disassemble to diagnose and get to the source of the problem.
