Hi can anyone tell me why this model would hiss loudly when the door is closed a little to hard or it is moved? it sounds like it is venting something is this normal it is only a few months old and it has only recently started thank in advance for any replies
Check the drain pipe at the rear of the machine for a blockage (in the defrost evaporator tray)
Seen similar with an Electrolux fridge freezer. As the door closes and the seal pulls it tightly shut air is forced out of the drain pipe (the air inside the cavity is compressed) and a small blockage caused it to make a hissing gurgling noise each time the door was shut.
