Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
Looking for a smarter way to manage your heating this winter? We’ve been testing the new Aqara Radiator Thermostat W600 to see how quiet, accurate and easy it is to use around the home. Click here read our review.
HI I HAVE A SAMSUNG RSH1DTMH AMERICAN STYLE SIDE BY SIDE FRIDGE FREEZER AND THE FRIDGE NO LONGER COOLS, IT STAYS AT ABOUT 10-12 DEGREES CAN ANYONE HELP WITH MY PROBLEM ? THANKS IN ADVANCE !
hi i have read and looked into the link you sent me and it was helpful in a way but it refers to a completely different fridge freezer so i have uploaded some photos of the back of mine, i have hoovered it all out ( quite a bit of dust !!) i have included a photo of the inside of the fridge section which appears to be icing up, i have defrosted these once and it keeps happening also if you look at the pipes coming from the black cylinder there appears to be signs of a leak or corrosion , what do you think ? thanks for the reply , mark. http://www.diynot.com/network/spen/albums/
on your picture 2 which is showing the problem remove cover check ice build up around fan etc and check the defrost heater and sensor same way as already told you
There are several possible faults that can cause this but by far and away the most common is the freezer needing a full defrost.
Switch off for min 24 hours, door to freezer open, keep an eye on the rear evaporator tray on or near the compressor to make sure it does not overflow.
Steer clear of a company called agsrefrigeration, they have some very shady practices.
For example, I wouldn't trust anyone who made multiple posts on DIY and consumer websites, using numerous false names, dishonestly pretending to be satisfied customers.
Would you?
Do your own search on agsrefrigeration and make up your own mind.
