Sander vibrating screws loose
2 Dec 2013
I have some metal back boxes screwed into wood panelling.
I sanded the panelling to tidy up where I had put filler over some screw heads etc, using a random-orbital sander.
While I was doing this, three of the five back box earth terminal screws completely unscrewed themselves and fell on the floor!
The screws were not tight - they’ve not been used yet.
Question: has anyone else seen this, and do you believe it could happen to terminals (earth or otherwise) that have been done up tight?
Not tight I guess was the reason.
It you think they are a bit easy to turn you can drag something down the thread. Rake the thread. That will give it some restriction but I don't think that's necessary.
Not really normal to have that level of vibration. Just confirming it's all tight when done and leave.
You will need to check cable screw but don't dog up tight forcing it
Should be ok if properly tightened but worth repeating the sanding as a test if it remains a concern
