Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
Looking for a smarter way to manage your heating this winter? We’ve been testing the new Aqara Radiator Thermostat W600 to see how quiet, accurate and easy it is to use around the home. Click here read our review.
What type of floorboards? If pine and sanded bare, applying a clear finish might turn it typical pine orange after a while.
We can recommend Colour Wax Oak, followed with 1 coat of Premiums HardWaxOil (4 sheens available) to prevent this and give you a warm, not to dark colour.
As for sanding the boards: a standard drum sander from hire-shops could give you loads of shatter marks, again especially when you have pine boards. Make sure the metal rod is tightly secured to the sanding paper and drum.
Make sure any visible nails are driven further through the boards, they can damage the sanding paper (and if you're really unlucky, the drum too)
