    Dismiss Notice
Sandstone foundations causing damp?
Discussion in 'General DIY' started by richardpb, 3 Feb 2020.
Tags:
  1. richardpb
    richardpb
    14 May 2013
    7
    Thanks Received:
    Heswall
    Country:
    Hello. A friend of mine owns a house who's foundations he says are built directly on sandstone. The house was rendered with an impervious cement render. He has damp downstairs on all the lower walls. He maintains this is due to the fact that it has sandstone foundation's. He also tells me that there is clay placed all around the house. Does anyone here know anything about this? He wants to sell it and I would like some advise as to how we could remedy this problem. Many thanks!
  2. sircerebus666
    sircerebus666
    31 Oct 2019
    424
    Thanks Received:
    67
    Country:
    Peeps on here are gonna need pics of the inside and outside of the house showing the damp so they can properly advise you
    Also when did the damp appear before or after the render was applied?
    It would also be better if he posted here himself
  3. Sponsored Links
  4. jj4091
    jj4091
    1 Dec 2006
    4,584
    Thanks Received:
    385
    Cumbria
    Country:
    "He wants to sell it and I would like some advise as to how we could remedy this problem. Many thanks!"
    Not something any one here will be able to you how to rectify, not a diy job by the sound of it. You need to get professional on site advice, a builder or damp proofing expert.
  5. foxhole
    foxhole
    14 Mar 2006
    14,915
    Thanks Received:
    1,604
    Kent
    Country:
    Failed render let’s it lots of moisture, but let’s none out, most likely cause along with roof , guttering problems. Foundations are of no consequence.
  6. Sponsored Links
Loading...
Share This Page
