sani split pump
2 Aug 2010
Suffolk
hi all i have a sani split pump maserator which can be a bit fickle, anyway the problem is the pump motor is continuously running do's anyone no how to fix this, i've pushed the reset but still the same.
cheers Rich
More likely needs a good clean out.
Useally due to the flow switch stuck with crud or worst flow switch is faulty.
ok thanks for that how do's it come apart i can see a large screw type knob at the clean end?
Rich
