saniflow plus up
14 May 2012
Hampshire
been ask to fit saniflow plus up the pipe is in 22mm out of the saniflo is it best to increase the size to 35 or keep it at 22 the doesn't conform to the best practice as it will have to run 2m horizontally before the vertical section the builder who wants the work says it has to be like that I don't have any experience of saniflo,s so hope this will work
2m horizontal before the vertical is not ideal however it will work, I'd keep it all in 22mm until the highest point then run 32mm to the stack. Worst case is you will knock a couple of years life off the motor.
(17yrs working with them)
thanks a lot that a bit like what I expected the builder only wants it too work how long is optional I think in copper is better as a pulled bend will give a better radius
You're welcome.
Plastic and 45's x 2 work fine. Cheaper and easy to step up to 32mm. ;)
Tell the customer to register it and get the extended warranty. :)
Paperwork will be in the box.
