Hi Guys,
Quick sanity check if I may.
I want to extend a ring main (add 3 extra double sockets) by extending off a single socket. For a variety of reasons it is not easy to access the wiring to rerun the cable to the original socket etc.
Is it OK to extend the original 2.5mm T&E using crimps (as seems to be suggested on this forum) in the original back box and cover with a blanking plate? There is not enough room to use terminal blocks.
Are these the correct connectors?
http://www.screwfix.com/prods/70554...Accessories/Crimps/Crimp-Red-Butt-Pack-of-100
using this crimper
http://www.screwfix.com/prods/70036...rs/Crimpers/Forge-Steel-Ratchet-Crimping-Tool
and do you have to cover with heat shrink?
http://www.screwfix.com/prods/17109...ies/Cable-Covers/96pc-Heat-Shrink-Tubing-pack
Mark[/url]
using this crimper
Mark[/url]
