Satelite installation
12 May 2016
Needs some advise please.
Just renovated a house and left all the coax satelite cables in the loft.
My question is do i take all the cables direct to the LNB (quad) or is there a switch i can buy 4 in and 1 out to the sattelite??
Or any additional gadgets i need for the install. Freeview only
For domestic installs, the cables go directly between the LNB and the receiver.
There are ways to split and distribute, but that requires additional equipment and it still needs 4 cables to the LNB.
Freeview is a terrestrial service, unrelated to satellites.
I have a hybrid LNB two outputs go to Sky Q box, and other 4 to old satellite boxes, the pair to Sky Q work different, but the 4 other outputs use the supply voltage to decide if vertical or horizontal polarised, so if I daisy chain the boxes first box selects vertical or horizontal so second box can only get half the programs.
So it is one output to each satellite box for most installations.
The central question remains though whether @Sid1968 is trying to use a satellite dish feed from the Quad LNB to feed signals to the aerial inputs on some tellies. If so, then the dog has rhe wrong scent.
I guess we'll have to wait though until he visits again and updates the thread. Anything else is just speculation on out part.
