The problem is I have water seeping from the pump on my Thelia 623 boiler in two places. Firstly, from the front where there is a brass serrated cap (to front of pump just behind boiler casing when opened) and the second leak to a pipe on the left which connects the pump to a jubilee clip and rubber hose and onto what is either the copper flow or return pipe. I am presuming the pump requires replacement however, is this a fairly straightforward job ie; just unbolting and bolting new unit back in place ? OR can it be taken apart and repaired ?
