H
huddsspread
Im an old skool plasterer ( 34 years old ) And when i am rendering i use sand,cement and waterproofer/feb. Sometimes i use wire ( render lathe to all you young spreads ).
But i have a job to do, and i am considerong using sbr bond on it first, as im always interested in new methods.
Its a painted concrete block wall, about 60m by 2m. It gets a bit wet from behind it and they want it rendered. The guy is a builder, and he seems to think that if i scratch and render it will be fine. But i really want to make sure the water don't come through.
After reading this forum i have thought about sbr bond, to paint over first, and then scratch ( wait till its tacky etc )
What i would like is your thoughts and advice. Should i knock up a sbr bond and cement sloppy paste? then paint it on? If i paint it on neat ill need about 12 tubs. I was also thinking of tanking it with tanking slurry first instead of sbr, giving it two coats, but how would that effect my Render after?
Any advice would be appreciated.
brad
if you look at the bottom right, thats a small corner of the block work-i have already rendered the brick work club, and they love it so much they want the wall doing too.
brad
