Scantronic 9448 replacement PCB setting up.
25 Oct 2024
In a power cut my 9448 alarm must have been damaged as when power was restored no green light came on and the board was dead. I've bought another main unit and swapped the PCB over and it's now up and working partly. I reset to the default settings and wired it up exactly as before. I can't work out from the instructions how to get all the room pir's to work. There are more pir sensors than zones but some work and others light up ok but don't trigger the alarm. They all worked previously. One sensor puts on the alarm instantly whereas most set off the countdown. A walk test shows the PIR's not sensing same result. How do I program them in to work again. Thanks in advance.
In the command list is the option zones omitted in part set? And another saying zones not used but it's really not clear what to set in the instructions. I've a hand written key suggesting what the zones were from 1 - 4 but I think an extra pir was added? Should I use the "zones not used" and set 1-4 as used only? We've never used part set. Can they have several pir's in one zone?
It’s the basic and most simple panel to program .. look at whats connected in the zones on the pcb 1-7 and if there isn’t wires in there …program it not used or link it out
