Hi Sparkymarka. I can confirm I have disconnected the wires in the panic terminals of the keypad replacing them with a small jumper wire and exited engineers mode and now all faults have cleared. I have also now reconnected panic terminals and we are able to set and unset the alarm again.
Reading the manuals a 100 times I don't think I would ever have fixed this on my own so you so much for your time and expert advise it is really appreciated.
I also hope these post can help somebody else out in the future.
i too have a scantronic 9751. the mains in my house kept tripping due to a faulty freezer - this kept making the alarm go off. I kept resetting it but now the fault 'K01 TAMPER - RESET REQUIRED' is prominent on display. i've tried resetting it with my code over a hundred times and see the date for a split second but it keeps returning to this error message. Any help is really appreciated.
Power the whole thing down (mains and battery) and up again - you could do a first stage reset at the same time to get an engineers code... Make sure that the battery is good and power it all up again. Replace the cover and try resetting again (tick, tick...). If succesful, don't forget to set the date and time (code, 6).
