Scantronic 9752 - part to partition
16 Aug 2012
London
Morning All,
I have a Scantronic 9752 currently setup with part set (A, B, C D) for different areas of the house to arm (eg windows, doors, down stairs, upstairs).
Use of the house has now changed a little, and want to change it to partitioned system - downstairs and upstairs. There are also a few 24 hour zones (panic, co2 and fire detector).
I've read enough in the manual to know I can change, but it indicates that I would need to re-setup all zones. Is this indicating that the entire setup will be wiped (ie I need to key in zone names again) or just the groupings would be reset (expected)
Just a case of following manual to assign zones to the areas you require them in then
So it wont reset the names, type etc of each zone when I change to partition?
according to the manual to change from a normal ….part set type system to a partition type system ( separate areas ) you have to do a 98 enter …..load defaults ….i would guess everything would need reprogramming
That's how I read it but wanted to check - looks like time to get notepad and pen out to write down all the zone details!
