Have you entered code number and pressed clear ?
Try and set and unset set alarm
Last resort total power down control panel then 're apply power mains first then connect battery.
Tried all those and not worked. Disconnected mains and connected battery which got rid of all the codes but left the fault light on. What would happen it just turned off mains and then turn back on without touching battery?
Battery is fully charged. Went through again what I'd done before with reconnecting battery with mains off then turning back on and fault light is still on.
