Screed depths for a garage conversion - Please HELP!
18 Sep 2012
Berkshire
Hi
Raising garage floor and need some better informed views;
DPM on floor (either 1200 gauge sheet or painted on stuff), 100mm Celotex then do I lay concrete, then screed or just straight screed?
How thick can Screed be laid - I think I will need (after the celotex) to raise the floor about 4-6 inches, could this just be screed?
Also Im hoping someone can simply drive up and pump the stuff through a hoze/window space onto garage floor?
Any help appreciated BN :LOL:
Dpm, celotex then screed directly on top.
Perhaps tape the joints with foil tape.
Brick the door up to dpc. Then do the floor so there is no need for any window access. Whilst you are at it try and do as much as you can inside the conversion prior to blocking off the access.
I figure placing a suspended floor, air bricks, insulation plus floor clearance is more "fiddly" than laying down Screed?!
Having a raised floor has its bonus's in that pipework etc can be hidden im just unsure how to raise the insulation to fix it under the floor...someone said chickenwire? and then I have to sort airbricks for ventilation? just a little more confusing to understand whats what I guess
Timber floor gives you more options to conceal pipes, cables etc . It really is easy to do. Feels better also undefoot.
If you lay a concrete floor- you have to decide how you will finish it (on surface). Asphalt ? (more expense) or paint it ?
Timber is my personal choice :)
