screed
29 Oct 2012
Bristol
Evening all,
Just got on to a job where the customers ground - workers have got the concrete in at the wrong level. In fairness I think they've just misread the drawings slightly, however, with the insulation i've got it looks like i've only got room for a 50-55mm S&C screed - is this enough?
Yes mate - All slab work done by others - i'm on shell and internals - but the make up was type 1, DPM, slab, Celotex (150mm) and then screed
Bloody hell, what the hell is 150mm celotex doing in there? Get that down to under 100mm and it'll still comply, job's a good'un!
We tend to work on 75mm or above.
55mm is very lean on an un-bonded screed. A bit too lean me thinks. It will not stand impact well and could 'curl' being so thin.
Is there UFH too?
I usually use my firm of spreads - a decent mob from down this way - the only thing is there never that comital with advice, hence me canvasing for opinion.
I've just done some measurements and I think I could get away with 100mm - i've got a standard construction (300mm therm/conc) extension with 100mm full fill in the walls and a flat roof deck with 120mm all over. small roof lantern and small french doors in?
Would 100mm work here?
