I HAVE A HARDWOOD WINDOW FRAME WHERE THE SCREW FOR THE HANDLE HAS PULLED OUT - CAN I USE FILLER TO REPAIR THIS THEN RE-SCREW- CAN ANYONE RECOMMEND A PRODUCT-THANKS
match sticks cocktail sticks oval shaped wittled bit of wood hammerd in tight until the hole is tightly filled
and if its brass screws insert a metal screw first [the same size or slightly smaller] to open the path
assuming your re-using the hole
