Screwfix External Render Beads?
18 Oct 2007
Invernesshire
Have any of you guys used Screwfixes white uPVC external render beads? I`m concerned they might be a bit cheap and flimsy. Do they come well packaged as they have to travel quite far to get to me?
I have, and disliked them. They're just not as stiff as a metal bead, so if you store them against a wall they develop a bow, and can easily kink.
They arrived safe and sound though - the courier wasn't an issue.
Gary
The only plastic beading that I use, is the one that goes around the radius of a plasterboard archway,the rest are too flimsy.For everything else,internal or external I would use galvanised or stainless steel.These come in longer lengths than plastic as well.
Roughcaster.
I thought the plastic angle bead is used for plastrboard?
You can use plastic corner beading for plasterboard,and some people probably do,but galvanised "thin coat bead" gives a stronger job, and is what most tradesman would use for the job.Again,they come in 3mtr lengths. Corner tape is also widely used,but again, I prefer not to use it, exept around plasterboard window reveals,or on any other corner that wont be taking any knocks.
Roughcaster.
