SDS drill extension bar
28 Feb 2010
Dorset
I need to drill a neat 75mm dia hole horizontally through about 600mm of old brickwork; it's only accessible from one side.
I've got an SDS drill and a 75mm dia core drill - but that will only go in about 150mm.
Is there such a thing as an extension bar with SDS type "clutch" on one end, and the standard SDS "male" the other end, to insert between the core bit and the drill itself ? If so, from where can I get one ? (And how much?)
Happy to help, I had a similar problem coring out a very thick yorkshire stone wall, a few years back. Needed either a longer arbour shaft or an extension bar, I managed to find an extension bar at 300mm, which did the job great, but cannot for the life in me remember where from. I did come across many at 150mm and 200mm but needed a little bit more, and got lucky I guess. Still got it in the kit.
