Sealing Advice Please
5 May 2014
Glasgow
We noticed that we were getting a damp patch under our dinning room window. When I checked the window outside I noticed that a lot of the paint had blown and the seal was broken in places.
I have started stripping everything around the window as I plan on re-sealing the window. However, when I started stripping I noticed that there are big gaps between the brick and the window [see photos].
Therefore, I was wondering what I should fill these gaps with before I reseal?
I also have UPVC facing to go back onto the brick work and was wondering if it was ok to use silicone as an adhesive, if not what should I use?
Would really appreciate a quick response as it is scheduled to rain tonight and I need to get this water tight before it does.
Yes the PVC trims are stuck on and sealed around with silicone.
You want low modules, Neutral cure silicone! And make sure the surfaces are clean before you seal them.
Ideally you want expanding foam in the big gaps just as a thermal and sound insulation, but unless your going to take the trims off all the windows and do them its not going to make a huge difference.
Depending how deep the holes are it could take 1-2 hours for the foam to go off.
Cheers mate.
I have now filled the gaps with expanding foam and learned that I should have taped over the UPVC and glass. I will put the beads back on tomorrow if weather permitting.
I do intend on re-sealing all the windows at some point so will do the same to them when I do.
