Sealing cracked toilet pan
14 May 2012
Leicestershire
I want to seal a crack in the outside of a toilet pan which leaves a little. It's an outside loo so not a major problem and it's a very fine crack but wets a tiled floor. Replacement would me a complete refurb. which I can't afford to do so I'd like to repair it if possible.
Droglite :(
20 Jan 2008
Lincolnshire
If it cracked thru structural movement, then its not safe to try and repair, best off with new bog. That,ll be better than removing chards of pot from yer arze.
26 Jun 2004
London
You should put salt in the pan of an outside loo during freezing weather!
If you dry out the pan and leave a few days you MIGHT get araldite to stick to the glaze and seal the crack from further leaking.
But is it only leaking to the outside and not to the underneath?
Tony
