sealing floorboards -stopping the draft get through 'em
30 May 2008
Nottinghamshire
Hello,
I have the floor up in the master bedroom at the moment and although I was toying with the idea of insulating under them I've decided not to, incase I stop the airflow and cause damp/rot etc etc.
So quite simply, how do I stop the air blowing up through the floorboards. Can I just use a silicon the gaps up, to stop the wind blowing through?
Is there anythign speacial I should be using or is normal white silicon good for the job?
Thanks :lol:
:( I bet it took you longer to type that than it would have to answer the question. Though you're right in your answer. :oops:
Thank you. Your magnanimity causes me to bow down before you.
But still use the search ! :D
Okay I've had a search and my options appear to be:
1. pull up all the floor boards and put down some plywood, then floorboards on top - im not going to do this
2. silicon the joints.
Can someone please advise if silicon is okay, I have searched now and not found that great a deal on the subject.
Thank you very much.
Jon
Google Geocel Dow Corning . There are dozens of silicones - one will be right for the job a white one probably won`t :lol:
saw it done once with sawdust and pva. mixa bit of pva in the dust to make a paste - fill cracks - when it hardens it's invisible...if you have got the sawdust from the same wood/type of wood!
