The booster would have to connect as a dead leg from the loop
This is meaningless without a diagram. (But I have just figured out what you mean) The OP has already asked what a "check valve" is, so I wouldn't expect him to understand what you have wrote above or how the piping layout is arranged.
(And anyway it wouldn't work)
Send me an E if you want a drawing.
To do this the OP would have to site his negative head pump in the loft close to the outlets. So the suction side of the pump will not be flooded and will be in negative head position.
This plan won't work. Plain and simple. Sorry.
Manufacturers advise siting the pump close to the base of the cylinder!
There's a couple of important reasons for this!
I will just reiterate my previous solution.
Fit the sec loop as usual and throttle the flow. You must maintain the pressure as it is a negative head system.
The pump is sited at the usual position. The base of the cylinder!
You could fit two valves and if the throttling doesn't work then fit the solenoid between the valves and just fit a timer to open the solenoid. Dead simple.
No extra pump needed and very little pipework involved.
kevendgas said:I don't think anyone is being stupid
What exactly is open vented about the discharge side of a negative head pump?
If you put a booster pump on an open vented cylinder return circuit, at best it will pump the water straight into the storage tank
Your getting there at last.![]()
(but not quite) The highlighted bit is the clue.![]()
and in any case you CANNOT use a booster pump as a secondary circuit pump
Are you saying the OP's pump is incapable of returning flow to the cylinder?
don't think anyone here is stupid! we are trying to find a solution to the OP's problem, by sharing ideas someone will come up with the way to do what is required
as I have suggested, this maybe possible with a header tank higher than any outlet
it is for the OP to tell us if this would be feasable, if it isn't then we can explore other ideas.
