when you two have finished **** between yourselfs![]()
don't think anyone here is stupid! we are trying to find a solution to the OP's problem, by sharing ideas someone will come up with the way to do what is required
as I have suggested, this maybe possible with a header tank higher than any outlet
it is for the OP to tell us if this would be feasable, if it isn't then we can explore other ideas.
lets go back to the original problem.
if you start with a header in the loft above the height of the loft bathroom, then feed into the hot water cylinder located say on the first floor with a single check valve to stop backflow.
you then have a surrey flange fitted using the side takeoff for the return of your circuit .
at the same time bringing down a cold feed as well
you now have 2 flow (hot and cold) and 1 hot return from cylinder to loft bathroom
with a bronze circulator pump in the hot return
flow pipes now enters pump which has enough water (remember header position) and that then pumps water to bathroom taps
any reason this won't work ?
Firstly You don't let the pump run wild. I have already suggested microbore pipe and throttling valves.
Secondly I have suggested fitting a timer to open the solenoid. In my experience running the pump for about 45 seconds is ample on most domestic premises. In this case the solenoid will be open for about the same time depending of course on just how much restriction is in the pipework.
A bronze pump does not deliver anything,
It delivers cold water in the loop back to the cylinder which is then replenished with hot water and none is wasted down the drain and the occupier is not standing whistling dixie as he waits for his hot water to arrive.
it's circulates the water around the circuit, if part of pipework is installed with a negative head it will not fill with water.
尝试最后一句英文请
I will just reiterate my previous solution.
Fit the sec loop as usual and throttle the flow. You must maintain the pressure as it is a negative head system.
The pump is sited at the usual position. The base of the cylinder!
You could fit two valves and if the throttling doesn't work then fit the solenoid between the valves and just fit a timer to open the solenoid. Dead simple.
No extra pump needed and very little pipework involved.
Yes Kevin that's exactly what you have to do, although if the storage tank is say 600mm above the secondary loop, raising the storage shouldn't be necessary, the check valve on the cold feed to the cylinder definitely isn't wanted.
bronze would be in the return part of the hot pipe don't think actual position should matter so long as it is in the return as all that pipe would be below header level as therefore should self prime. only thing i'm now thinking which maybe what you are thinking. is would the neg pump suck the return? if so again a single check could be put in the return
