Securing new hob in worktop
27 Oct 2003
Really simple question - when installing an electric ceramic hob into the worktop can it just be dropped into the hole or should it be glued in, and if so what adhesive should be used?
James
iv just removed mine, the old unit did have a seal around the worktop edge, i would recommend one for waterproofing/any slight uneveness in worktop (or appliance) but afraid i wouldnt no what to use. I would imaging it needs to be highly heat resistant tho. be helpful if anyone knows what to use??
what do the instructions say.
If it comes with a seal use it.
If comes with brackets use them.
My hob is on ceramic tiles (uneven) it is bedded onto plumbers mait, there is no heat problem & it forms a seal, it also holds the hob firmly & can be removed.
What is your work top made of?
