securing the plug in expanders for texecom
30 Mar 2015
Hi All,
I've plugged one of these onto the panel and it's registered fine. I can now see the zones on the keypad.
Q. How do I secure this to the main circuit board? I can see the holes but it hasn't come with any fixings or instructions.
If it's an enconomy plug on expander (24 only ) it should have some plastic pcb pillars that clip in
It's one of these and it definitely hasn't come with any fittings: Texecom Premier 8XE Expander
Can I buy these separately or use something else? I'm worried as it lifted from the end that is not plugged into the connectors.
it definitely should have come with plastic pillars, if you haven't got them, contact your supplier or Texecom, I imagine they will be choc a block busy at the moment but they will usually send you some.
