Hi. Just a quick question regarding replacing misted up units into hardwood frames. I am about to order some security glazing tape using the dry glazing method. The tape comes in 2,3,4mm etc. thicknesses and compresses about 20%. What should be the ideal mm gap between glass and frame when fitted. I can then work out which thickness to buy after accounting for the compression. It is hard to judge the current gaps as some are minimal and some are quite big. Obviously fitted by different people over the years as some are siliconed in and some bedded in putty. Any advice appreciated.
