I have in my house PIR security lighing (500w) front and back. This is powered by a cable ran through the window frame and then plugged into a single gang socket. ( previous owner) I intend to run a 2.5mm
T+E spur off the socket (ring main) to a FCU (3 Amp) and then connect to the security lighting.
First question
Is the above reasonable or is there a better way?
Second question
As this is adding a spur to an exsisting ring the work is non notifiable as I understand it. Am I correct?
Many thanks
First question
Second question
Many thanks
