Hi All,
Sorry for the long post but i'm in the middle of a tiling a disaster on my kitchen floor. The kitchen is in a 1970's extension with a concrete slab floor. I removed two layers of different lino before levelling it with Bostik Cempolay deep after priming with acrylic primer. The SLC was varying in thickness from about 35mm to 10mm.
Over this I laid 60x60 porcelain tiles which looked fab for around 2 days before before I could see them starting to lift up in the corner of the room. After a month or so patch about 2m2 had started cracking and lifting. In the end I bit the bullet and pulled up the offending area to find that the SLC had completely delaminated from the concrete.
After pulling up all the loose SLC I cleaned and reprimed the area with SBR and relevelled it to match up with the surrounding sound areas, this time in two goes each half thickness. After leaving it for about 3 weeks I noticed it starting to crack in roughly the same area and after about a month again it had completely buckled and delaminated again.
So having wasted a few hundred pounds of materials and hours of my life I had to rip up the failed SLC again and scratch my head as to what to do. I've checked the concrete, there are a few small cracks maybe 2mm across but none of them have any vertical height difference and the concrete slab has been down for many years. I checked with a polythene sheet and moisture meter and there doesn't seem to be any damp coming through although I can't say for certain if the DPM is intact. There are some hollow sounding areas of the slab but no obvious signs of movement
The lino was well stuck down so in some areas there's a cream coloured residue (possibly adhesive) which is almost impossible to get rid of, although the SLC didn't really adhere to the bear concrete patches either.
I'm really at a loss as to what to do next, I've a few ideas but don't really have the heart to waste more time and money ad have to rip it up for a thid time, to make matters worse my 6 month old will be crawling soon and missus wants this sorted ASAP. My options?
- Liquid DPM, resin inject cracks and use a different levelling compound?
- Laying plywood over packers and screw down, tile over with Ditra mat? I'd be a bit worried about how to get the ply level and also the washing machine and dishwasher sit on this area so it would need to be pretty solid.
- Tile directly onto concrete with thick bed adhesive?
- Dig out concrete floor and start again? Not really an option as the kitchen is already fitted!!
None of these sound like good ideas but need to give something a shot.
Any words of advice much appreciated, thanks!!
Garry
Garry
