Hi
I’m going to attempt to level my conservatory floor. It’s not level and is about ½ to 1 inch lower that my kitchen, which it’s attached to. I’ve heard if the layer is to thin it will crack? If anyone could give me any advice on, what’s the best stuff to use? what’s the minimum thickness the layer can be? and how to get it level? I’d be very grateful.
Thanks!
Paul
Interesting method Roy..
If your new to floor levelling which Im guessing you are by your question, you would be best off to use self levelling compound.
My klocal merchants sells two types...one is for up to 10mm thickness of coverage, and the other type is for I think 10-50mm thickness.
Whay do you ask what is the minimum thickness it can be? it can be used down to 5mm ish as an average coverage depth (of course some areas are less, and some are more).
its easy to use. Mix what you need out of the bag (floorsize) as per the instructions, to a Mcdonalds milkshake consistency (or a little finer)
and then use a plastering trowel.
use a good bucket and find the lowest point in the room. Work out where you can stand as you do the work, otherwise you may get marooned on an island of floor
Pour it in to the deep end and using the trowel push it around the floor to even coverage, continue pouring and moving back across the room and levelling as you go, continue all the waw to the door/exit and finish levelling there.
it basically does 'self level' and moving it around with the trowel is so that it gets in all areas....it should settle to a flat finish and skim over it if there are any lumps.
make sure you have another route out of the house if this room is part of your throughfare. As it cant be walked on for a good few hours (check teh pack). THe last stuff I used was 12 hours till solid
