Semi gloss / satin
RMS
8 May 2006
Hi
I'm after some semi gloss oil based paint in black. Is this he same as satin. I am looking at dulux trade satinwood and am wondering if this is the same as semi gloss.
I am open to suggestions of other brands but need the finish to be semi gloss.
Thanks for your help
An arcade machine made from mdf. It's had a primer coat and two coats of johnstones trade undercoat - dark grey.
What's the difference between eggshell and satin?
I think I'd rather go with an oil based paint as I will be applying it with a high density foam roller. Am I right in thinking that a water based paint will be harder to apply due to the quicker drying time?
The difference between eggshell and satin is in the degree of sheen. Eggshell is flatter/matter than satin. Typically full gloss paint has about 95% sheen, eggshell about 20% and satin (depending on make) is somewhere in between.
Only apply paint with a roller if you don't mind an orange-peel textured finish. Otherwise, you can apply with a roller but lay off with the tips of an appropriately wide brush whilst still wet.
Water based paint is indeed harder to get a perfect finish with, but it doesn't smell, and the quick drying time means it is less likely to pick up dust, hairs, etc. before it is dry.
That said, F & B oil based eggshell is touch dry within four hours.
Little Greene w/b eggshell is nice too and you can get a brush-stroke free finish if you're careful and are willing to use u/c and at least two topcoats.
Satin has more of a sheen to it, less than gloss though.
What sort of finish are you after? The reason I ask is if you look at a fruit machine for example it has a bit of texture to it. If you was to roll on a water based satin you would get a similar affect.
When researching the paint people use to paint arcade machines it tends to be semi gloss black paint, but most are based in America. That's why I asked what the difference was between this and satin and eggshell.
I don't want a matt finish, I want a bit off a sheen but not too much. When I have applied the undercoat with a high density gloss roller it has left a slight texture to it which I am more than happy with.
I think oil based will be easier for me to apply and harder wearing.
Here is an example of the finish I want, it's probably hard to tell from a picture. First picture.
https://www.google.co.uk/search?q=p...oAQ&biw=768&bih=928#biv=i|0;d|rl5Bh1mR5nlRMM:
What do people think......satin or eggshell? Apparently, sadolin semi gloss was used to paint the arcade machine in the picture
