It just seemed odd that cables down and against block or brickwork that would be plastered over would require clipping and not so when hanging loose inside a partition.
Cables which are to be plastered over don't really need to be clipped, per se, although they often will be clipped a little to keep them in place whilst being plastered. As you've been told, all the regs require that all cables (no matter where located/routed) should be 'adequately supported', the regs themselves give no specific definition or details about that. I agree it's a bit odd that a cable should be left 'hanging loose' within a wall in a manner which probably most would regard as unacceptable if it were on the surface of a wall - but, as I implied, I think you'd have to look very hard to find an electrician digging holes in a stud wall in order to clip a cable! In other words, 'practicability' seems to win the day in this situation!
Kind Regards, John
