Afternoon all,
I'll try to summarise this to make it easier to understand and answer.
Yesterday I added some Wickes Inhibitor via filling loop attachment as there was almost none in the system. Once that was placed in the pressure rose from about 1.5 bar cold to 1.8. I then put c/h on to flow it around and pressure got to 2.5 bar and i turned boiler off and opened some rad valves to get it back to 1.5 (even though it had just switched off)
I also let some air out of the expansion vessel to check there was no water coming out and that was fine but last night once the c/h had got up to temp it kept cycling between: fan on, burners off, on for 10 sec then off again for 15.
I've now got up this morning and the pressure has dropped to almost 0 bar!
Before anyone says there are no leaks they're aren't, this must be something to do with the draining of rads when just turned off, letting air out expansion vessel or something else..
So basically how do I sort this. Do I re-pressurise via the filling loop to about 1.3 cold or pump up the expansion vessel with a bike pump ( to what pressure).
Any more information required please let me know.
Regards
BW
Regards
BW
