Servis Washer Easi Logic 1600 Fault
13 Sep 2014
Nottinghamshire
Hello can anyone give me some advice on this fault please. On a 40/50oC cycle the washer fills with water (not completely) water heats up but drum doesn't revolve, pump removes water, then it doesn't refill with water to rinse, doesn't spin, programme ends & switches off after a few minutes on a wash cycle which normally would take 1hour 40 mins. Somebody suggested it may be the PCB which is expensive. Can anyone help me please? Thank you
1 Dec 2006
Cumbria
Drive belt & motor brushes would be the first things I would look at.
13 Sep 2014
Nottinghamshire
Thanks for your quick reply, however when use spin mode on program switch it will spin normally, which indicated that the pcb could be faulty as its not cycling through the selected program, but I will check this a let you know thanks.
