Set a Galaxy 500 system correctly
Hi GalaxyGuy and others
Apologies I didn't see you'd posted at #11 so didn't mean to seem ignorant. You've all given me food for thought so really, thanks again.
No worries. Hopefully, if you follow the instructions, you'll get your system sorted out.
Hiya
The following are in 53 PROGRAM OUTPUTS:-
1001 BELLS L
POS
01=BELLS
1002 STROBE L
POS
02=STROBE
1003 PA L
POS
03=PA
1004 RESET L
POS
07=RESET
1021 BELLS L
POS
01=BELLS
1022 STROBE L
POS
02=STROBE
1023 PA L
POS
03=PA
1024 RESET L
POS
07=RESET
_*99 E/E HORN L
POS
18=E/E HORN
_*10 E/E HORN L
POS
18=E/E HORN
_*20 E/E HORN L
POS
18=E/E HORN
_*30 E/E HORN L
POS
18=E/E HORN
Each output function had a letter L after its description
The output mode of each function is set to LATCH
Groups are disabled as in option 63
Any ideas?
Is that within a metal box about a foot square by two inches deep? Would any tampering be detected if I opened it?
I have to ask because everyone I get into engineers mode the alarm rings for a couple of seconds, thus alerting my neighbours. If I open that box I mentioned would some kind of tampering alarm go off or next time the alarm is set anyway?
When you are entering engineering mode, it should only be the internal sounders that warn that someone is entering that mode. Entering the engineering code a second time silences the internal sounders and allows you to continue in engineering mode. In engineering mode, the system tampers are ignored, allowing you to open the panel enclosure. Please be aware that there are mains voltages present inside the enclosure, so if you are not technically competent, then it's best to get someone else to resolve your systems issues.
